Constraints
Assume that you have two properties
rand bit [7:0]a;
rand bit [2:0]b;
The range of values for b are 3,4,7
If b==3, the number of ones in the binary number must be 4.
If b==4, the number of ones in the binary number must be 5.
If b==7, the number of ones in the binary number must be 8.
Write constraints for above scenario.
In reply to Rakesh Kumar S:
Hint: use $countones(a)
module example;
class ex;
 rand bit [7:0]a;
 rand bit [2:0]b;
  constraint range {b dist {7:=2,4:=2,3:=2};}
 constraint count {$countones(a)==(b+1); }
ex ex1;
initial
   repeat(10)
   ex1=new();
   assert(ex1.randomize);
     $display("a=%b,b=%d",ex1.a,ex1.b);
