It always helps to show the error. It explains the problem
array is an unpacked array of 1-bit elements. 'b10110100 represents a packed array of bits, an integral value. You can’t compare an unpacked array with a packed array. Also, constraints cannot involve unpacked array expression unless you iterate over their elements with a foreach or an unpacked array reduction method.
class some_class;
rand bit array[];
const bit [0:7] constant_value = 'b10110100;
constraint array_c{
array.size == 20;
foreach (array[i])
if (i inside {[0:7]})
soft array[i] == constant_value[i];
Keep in mind that dynamic arrays have index bounds from 0 to size-1. So be careful if you want array[0] to have the value 1 or 0.
randomize queue such that it should contain elements of another queue.
output is giving not as expected .
qu size is = 5
qu = '{'hd8, 'h85, 'h82, 'h95, ‘haf} //expected is qu =’{'h1,'h2,'h3,'h4,'h5}//or any values of qu_1 queue
class queue_rand;
rand bit [7:0] qu[$];
rand bit [7:0] qu_1[$] = {1,2,3,4,5,11,23};
constraint size_c { qu.size() inside {[4:10]}; }
constraint constraint_3{foreach(qu[i]) (qu[i] inside {qu_1[i]});}
function void display();
$display("qu size is = %0d",qu.size());
$display("qu = %p",qu);
module queue_randomization;
queue_rand pkt;
pkt = new();
pkt.randomize();
pkt.display();
