I am looking for an optimized solution for a constraint on array elements . For instance if we want the array elements of a dynamic array to be in descending order a foreach as shown below will work fine for smaller arrays but is there a more efficient solution ? How can we write up constraints that can target each element of an array ?
eg. to get the array elements to be in descending order
class dyn_array;
rand int abc;
constraint abc_descending_c{
abc.size() == 5;
foreach(abc[i]) begin
abc[i] > abc[i+1];
Minor change:
class dyn_array;
rand int abc;
abc.size() == 5;
if(i!=abc.size()-1)// to make sure abc[5] doesnt get accessed
abc[i] > abc[i+1];
I also tried this code :
class dyn_arr;
rand int abc[];
constraint abc_c {
abc.size()==5;
function post_randomize();
abc=abc.rsort();
but I am getting this error : $unit, “abc.rsort”
The call to predefined void function is not allowed in this context.
Cannot use a void function call where an expression is required
Can you please tell why the error - The call to predefined void function is not allowed in this context. Cannot use a void function call where an expression is required
occurs and how adding ‘unique’ resolves the issue…
I wrote some constraints, one of them is constraint con_arr {unique {my_req}; } my_req defines: rand int my_req[10]. then when I ask AI to check my code, it prints: The constraint unique {my_req}does not create unique values for the elements inside the array. but here I also see you use unique {abc}; so which one is correct?
