Constraints for a queue/array: Need help to understand how to implement this #3 condition
create a list of instructions (size=20) from ADD, MUL, SUB and NOP instructions.
  1. Such that No add instruction is repeated in 3 clock cycles and
  2. MUL is not repeated in 4 clock cycles and
  3. SUB is not repeated in the last 3 valid instructions.
    (I don’t understand how to implement this #3)
Valid instruction = any other instruction except “nop” . “nop” is considered empty cycle do nothing instruction.
instruction cycle #
ADD 1
MUL 2
SUB 3
ADD 4
NOP 4
NOP 4
ADD 5
MUL 6
SUB 7
// assuming "1" = add instruction. Later can define as enum
// assuming "2" = mul inst.
// assuming "3" = sub inst.
// assuming "4" = nop inst.
class A;
  rand int q[$];
  constraint q_c {
        q.size == 21;
        foreach (q[i]) {
				q[i] inside {[1:4]};
				//q[i] == 1 -> q[i+1] != 1 -> q[i+2] != 1;
	            if (q[i] == 1) {
	              q[i+1] != 1;
	              q[i+2] != 1;
				//q[i] == 2 -> q[i+1] != 2 -> q[i+2] != 2 -> q[i+3] != 2;
                  if (q[i] == 2) {
                    q[i+1] != 2;
                    q[i+2] != 2;
                    q[i+3] != 2;
   A a_h;
      repeat (5) begin
          a_h = new();
          a_h.randomize();
          $display("***************************** q =  %0p ****************************************", a_h.q);
EDIT: Gives correct output for scenario 1 and scenario 2.
But need help with #3 implementation
***************************** q =  '{3, 2, 3, 3, 4, 4, 4, 3, 1, 4, 3, 4, 3, 2, 4, 4, 1, 2, 3, 4, 4}  ****************************************
***************************** q =  '{1, 4, 4, 2, 4, 1, 3, 2, 1, 4, 4, 2, 4, 3, 1, 4, 4, 2, 3, 1, 3}  ****************************************
***************************** q =  '{2, 3, 4, 4, 4, 4, 3, 3, 4, 4, 3, 4, 2, 1, 4, 4, 1, 2, 4, 1, 3}  ****************************************
***************************** q =  '{3, 3, 3, 3, 2, 4, 1, 3, 3, 2, 3, 1, 4, 2, 4, 3, 4, 4, 3, 3, 1}  ****************************************
***************************** q =  '{4, 1, 4, 4, 3, 3, 1, 3, 3, 3, 4, 1, 2, 4, 3, 4, 3, 1, 2, 4, 3}  ****************************************
In reply to vickydhudashia:
The issue is the Max index of the queue is 20 .
So q[21] , q[22] , q[23] don’t exist
The Error arises since your constraint tries to access such invalid indexes .
Constraint  Guard  is helpful such  cases  (  Refer  LRM  for  more  info  )
 constraint q_c {
            q.size == 21;
          foreach (q[i])
            if (q[i] == 1)
              if( i <  19 )    //  Constraint  Guard
                q[i+1] != 1;
                q[i+2] != 1;
              if (q[i] == 2)
             {  if( i < 18 )   //  Constraint  Guard
                  q[i+1] != 2;
                  q[i+2] != 2;
                  q[i+3] != 2;
In reply to ABD_91:
Hi ABD_91, Thanks, Yes I thought about it, But still real problem is with #3 implementation. I still can’t figure out a way to implement that constraint or any other way like in post-randomization/ late-randomization.
Let me edit Title & Post to avoid confusion.
It would help if you actually did use an enumerated type to begin with. It would make your code much easier to read. Another piece of advice: do not use queues unless you plan to push/pop elements, they are not as efficient as dynamic arrays.
It’s hard to know from your question how programmable the constraints needs to be. There is always the brute force hardcoded constraint.
typedef enum { ADD=1,MUL,SUB,NOP} instruction_e;
class A;
  rand instruction_e list[] = new[20];
  constraint q_c {
    foreach (list[i]) {
      if (i< 17 && list[i] == ADD) {
        list[i+1] != ADD;
        list[i+2] != ADD;
      if (i< 16 && list[i] == MUL) {
        list[i+1] != MUL;
        list[i+2] != MUL;
        list[i+3] != MUL;
    (list[17]!=SUB || list[18]!=SUB) &&
    (list[18]!=SUB || list[19]!=SUB) &&
    (list[17]!=SUB || list[19]!=SUB);
   A a_h;
      repeat (5) begin
          a_h = new();
        assert(a_h.randomize());
        $display("***************************** list =  %0p ****************************************", a_h.list);
Hi Dave, Thanks for reply, I will keep in mind for next timess…
I think I was not clear on my 3rd requirenment.
Anywhere in my instruction list, I can have SUB operation only if there wasn’t SUB instruction in previous 3 valid instructions.
If there is NOP instruction, consider it as you did’t have any operation/ that place in list is empty
So question is how do i create constraint/ do any post randomization check/edit for sub operations ? NOP can come any number of times. But I need to keep track of last 3 valid instructions and if SUB was not one of them, then only I can have SUB operation.
***************************** list =  '{MUL, ADD, NOP, SUB,  SUB, ADD, MUL, SUB, SUB, SUB, SUB, ADD, SUB, SUB, MUL, SUB, NOP, ADD, ADD, NOP}  ****************************************
                                         V    V        V,1st V,2nd
                                                             X - Should not come here since before this SUB instruction, last 3 valid instructions were MUL, ADD, SUB
Ex (invalid case):
ADD, MUL, SUB, NOP, NOP, NOP, NOP, NOP, NOP, SUB, NOP . . . .
 V    V   V,1st                              V,2nd
                                              X - Should not come here since last 3 valid instructions were ADD, MUL, SUB
Ex (valid case):
ADD, MUL, SUB, NOP, ADD, NOP, MUL, NOP, ADD, SUB, NOP . . . .
 V    V   V,1st      V         V         V   V,2nd
                                              Correct - since last 3 valid instructions were ADD, MUL, ADD
OK, those examples really help. Try this
class A;
  constraint q_c {
    foreach (list[i]) {
        list[i+1] != ADD;
        list[i+2] != ADD;
        list[i+1] != MUL;
        list[i+2] != MUL;
        list[i+3] != MUL;
      foreach (list[j])
        if(i<j && list[i]==SUB && list[j]==SUB)
          list.sum() with (int'(item.index inside {[i+1:j-1]} && item != NOP)) >= 3;
   A a_h;
      repeat (10) begin
          a_h = new();
        assert(a_h.randomize() );
Thank you Dave! Knowing this way of using array method makes me feel a little wiser !!
I did slight modification to first 2 conditions and here is the complete code that generates expected output.
class A;
  constraint q_c {
    foreach (list[i]) {
      if (i< 18 && list[i] == ADD) {
         list[i+1] != ADD;
         list[i+2] != ADD;
      if (i< 19 && list[i] == ADD) {
         list[i+1] != ADD;
      if (i< 17 && list[i] == MUL) {
        list[i+1] != MUL;
        list[i+2] != MUL;
        list[i+3] != MUL;
      } else
      if (i< 18 && list[i] == MUL) {
        list[i+1] != MUL;
        list[i+2] != MUL;
      } else
      if (i< 19 && list[i] == MUL) {
        list[i+1] != MUL;
      foreach (list[j])
   A a_h;
      repeat (10) begin
          a_h = new();
BTW, since we are now using a nested foreach loop, it’s easer to write the other constraints that way as well. No need for out of bounds checking.
class A;
  constraint q_c {
    foreach (list[i]) {
      foreach (list[j])
        if(i<j) {
          if (list[i]==ADD && list[j]==ADD) j-i >= 3;
          if (list[i]==MUL && list[j]==MUL) j-i >= 4;
          if (list[i]==SUB && list[j]==SUB)
Thanks Dave. That’s even better and cleaner !!
Why do we need else in the below? the if its self will ensure element element+1 and element+2 up to element 17,18,19 arent ADD. correct?
list[i+1] != ADD;
list[i+2] != ADD;
list[i+1] != ADD;
Might not be as optimized a solution like Dave provided. But this works for me.
class instr;
  typedef enum {
    ADD,
    MUL,
    SUB,
    NOP
  } instr_t;
  rand instr_t ins;
  instr_t      last3_valid_instr_q[$];
  instr_t      last4_instr_q[$];
  instr_t      last3_instr_q[$];
  //No add instruction is repeated in 3 clock cycles
  constraint c1 {
    ADD inside {last3_instr_q} -> ins != ADD;
  //MUL is not repeated in 4 clock cycles
  constraint c2 {
    MUL inside {last4_instr_q} -> ins != MUL;
  //SUB is not repeated in the last 3 valid instructions.
  constraint c3 {
    SUB inside {last3_valid_instr_q} -> ins != SUB;
    //Populating last3_valid_instr_q
    if(ins != NOP) begin
    	if(last3_valid_instr_q.size == 3)
      		last3_valid_instr_q.pop_front;
      	last3_valid_instr_q.push_back(ins);
    //populating last4_instr_q
    if(last4_instr_q.size == 4)
      last4_instr_q.pop_front;
    last4_instr_q.push_back(ins);
    //populating last3_instr_q
    if(last3_instr_q.size == 3)
      last3_instr_q.pop_front;
    last3_instr_q.push_back(ins);
    instr in;
    in = new;
    repeat(100) begin
      in.randomize();
      $display("%p",in.ins);
In reply to imajeeth:
Could you please let me know why you added “if else” only in case of last3_valid_instr_q in post_randomize
In reply to Grace90:
Thank you for the catch. I updated the code. I think that else is not needed there.
To satisfy the 3rd condition, shouldn’t the last ‘if’ statement be something like this?
list.sum() with (int'(item.index inside {[i+1:j-1]} && item != NOP && item != SUB)) >= 3;
That check is unnecessary because the constraint only needs to check the minimum distance between i and k.
Thanks for the clarification.
@dave_59 I try to use the find_index built-in function here. is it not supported in constraint?
such as:
typedef enum {add, mul, sub, nop} instructions;
  rand instructions ins[];
  rand int add1[$];
  constraint con_add {add1 == ins.find_index() with (item == add); }
but it has the error:
xmsim: *E,RNDCNSTE (./testbench.sv,11|43): Randomization constraint has this error, which will cause the randomize function to return 0 and no new rand values will be set:
Unsupported builtin function call in constraint.
find_index() returns a queue of int which you are trying to compare with another queue of int. Queues (or any other unpacked array) cannot be used in a constraint expression unless they are unrolled with a foreach construct, or used with a reduction method (like sum())
class A;
  constraint q_c {
    foreach (list[i]) {
      foreach (list[j])
        if(i<j) {
Hi, In Dave’s code above, it says if(i<j) { … and then j-i >= 3 (which doesn’t fit it, if at all it fits, j-i will be negative, right? Am I missing something here? or is this a dead line of code here? Thanks
Not sure what you mean by “which doesn’t fit it”.
Take the case where i=10 and j=11. Then j-i >= 3 is false, which means list[10]==ADD && list[11]==ADD must not be true.
Then the case where i=10 and j=15. Then j-i >= 3 is true, which means list[10]==ADD && list[15]==ADD may be true or false.
