In reply to avpchandra:
Sorry, then maybe I should have written
constraint AA_C { $countones(const'(AA) ^ AA) <= 16;}
But I’m not sure how you are defining a transition, Can you give a few examples and explain how you count transitions. The only example you gave was a 4-bit value, and AA is 24 bits.
Thank you for sharing. Unfortunately this syntax only works with questa!
class jh;
randc bit [24:0] g;
constraint fhg{counth(g) <= 16;}
function int counth(bit [24:0] j);
foreach(j[i])
if(i > 0)
if(j[i-1] != j[i])
++counth;
In reply to srikanth_6313:
Instead of inserting an if-else condition Can we go with the arithmetic right shift?
class A;
rand bit [23:0]AA;
constraint AA_C {
$countones(AA ^ (AA >>> 1)) <= 16;
Could you please explain how const will behave during the first randomize call ? I understand in the subsequent randomizations the const’ will treat the value of AA as sampled from previous randomization.
That’s not entirely accurate. A const cast returns the value of the expression inside the cast before the solver assigns any new random values. Therefore, technically, it’s the value of the expression after the pre_randomize() function is called and before the solver assigns any values to random variables.
