I have two class member arrays:
rand bit [3:0] grp_depth[num_of_groups]; rand bit [15:0] sub_grp_enables[num_of_sub_groups]
now each group has all the sub_groups with randomly enabled 16bits. each bit enabled means 4Bytes of space.
Now total such size needs to be within a given size. Want these grps and subgroups and number of elements in that group to be randomly selected.
theoretical requirement expression =
for (int i=0; i<num_of_groups;i++)
for (int j=0; j<num_of_sub_grps;j++)
for (int k=0; k<15; k++)
if (sub_grp_enables[j][k]==1) total_size+=grp_depth[i];
this size should be less than 512KB
So how do i write random constraint to enable this size restriction while generating grp_depth and grp_enables randomly?
I am trying to write something like this if i solve the expression taking out the common groups. But i cannot use … in the real code :(
constraint RAM_SIZE_c {
($countones(sub_group[0]) + $countones(sub_group[1])+...+$countones(sub_group[`num_of_sub_groups]) )*
(grp_depth[0]+grp_depth[1]+....+grp_depth[num_of_groups]) <= 512KB
Any good suggestions?
Thanks and Regards,
Lakshmi Kanth
