How to write constraint to print
1 22 333 4444 55555?
I tried to use foreach loop but can’t get the output.
class cons_pattern;
rand int arr[5];
constraint c1 {foreach(arr[i])
arr[i]==pattern(i);
function int pattern(int i);
static int num=1;
int res;
res=(i+1) *num;
num=num+10**(i+1);
return res;
It prints this output.
array : '{1, 22, 93, 244, 505}
//1 22 333 4444 55555
class trans;
parameter num=5;
bit [3:0] q[$];
rand bit [3:0] k[num];
function bit [3:0] varr1 (integer j);
for(int i=0;i<j;i++)
q.push_back(j);
varr1 = j;
constraint cond{
foreach(k[i]){
k[i] == varr1(i+1);
$display("array : %0p",q);
endfunction : post_randomize
endclass : trans
trans tr;
module tb;
tr = new();
tr.randomize();
endmodule : tb
i tried above code and it works using cadence and questa tool. Is there any other way to write its constraint and without writing any logic in post randomize function?
inside function change these 2 lines, it will work
res=(i+1) * num;
num=num+10**(i+1);
Calling a function in a constraint with side-effects is unpredictable because you can’t control how many times the function gets called in the evaluation of a constraint.
class first;
rand int ar[][];
int a[$];
function new();
$display("Inside first");
constraint ct{
ar.size()==6;
foreach(ar[i]){
ar[i].size()==i+1;
foreach(ar[i,j])
ar[i][j] == i+1;
foreach(ar[i,j])
a.push_back(ar[i][j]);
function dis();
$display("ar=%p",a);
first f=new();
f.randomize();
f.dis();
//output
Inside first
value ar='{1, 2, 2, 3, 3, 3, 4, 4, 4, 4, 5, 5, 5, 5, 5, 6, 6, 6, 6, 6, 6}
Thank you
class pattern;
rand int a[];
constraint c2 { a.size==6;}
constraint c1 { foreach (a[i])
a[i]==(1*(i+1)*(10**(i+1)-1))/9;}
module m;
pattern p;
initial
p=new;
assert(p.randomize);
foreach(p.a[i])
$display("pattern is %d",p.a[i]);
thought this is simpler
class my_class;
rand bit[3:0] my_q[$];
rand bit[3:0] temp_val;
constraint c1{
temp_val inside {[1:9]};
function void pre_randomize();
my_q.delete();
for(int i=temp_val;i>0;i=i-1) begin
repeat(i) begin
my_q.push_front(i);
my_class m1;
m1=new();
repeat(5) begin
m1.randomize();
$display("Value of temp_val=%0d",m1.temp_val);
foreach(m1.my_q[i]) begin
$write("%0d",m1.my_q[i]);
$display("\n=========");
// Code your testbench here
// or browse Examples
class test;
// pattern: 1223334444
rand int unsigned value;
int unsigned count;
int unsigned curr_num = 1;
int unsigned val_q[$];
constraint cons{
if(curr_num == 1) {
value == 1;
else if(count < curr_num) {
value == curr_num;
count++;
if(count == curr_num) begin
curr_num++;
count=0;
val_q.push_back(value);
endclass : test
module tb;
test t = new();
repeat(50) begin
assert(t.randomize());
$display(" %0p", t.val_q);
endmodule : tb
