I want to write a constraint to generate random start and end addresses to pick a block of memory inside a particular range of addresses, and i cannot use the address range which picked previous. can you please help me to write a constraint that pick start and end addresses for 10 blocks with in 0 to 1023 address range.
method i tried :
constraint c_rand_mem_block {
foreach(start_addr[i])
start_addr[i] inside {0:1022};
unique{start_addr};
// randomizing the start address and generate the end addresses with in the each start address.
foreach(end_addr[i])
end_addr[i] inside {start_addr[i]+1 : next_start(start_addr[i])-1};
// here next_start is the start address followed by the current start address.
// I am trying to keep the end address within the next start address.
but the issue is i am using a function to get the next_start and whenever this is called in the foreach of the end_addr the start_addr is randomizing again so, the previous start_addr values are not useful and dont match the end_addr.
Please help me to solve this issue or please tell me if there is a better way to do the same constraint
Jaswanth.
