Constraint to generate a pattern
Write a constraint to generate a pattern 10110011100011110000…
I have tried this with constraint but i am not getting the output
could you please add wha you tried that did not work.
class pattern;
  rand int intA[$];
  constraint intA_c{
    intA.size()==55;
  function void pre_randomize();
    for (int i=0;i<10;i++)begin
      for (int j=0;j<i+1;j++)begin
        intA.push_back(1);
      for(int j=0;j<i+1;j++)begin
        intA.push_back(0);
    $display("intA=%0p",intA);
  pattern c_h = new();
    c_h.randomize();
    //$display("Pattern = %0p",c_h);
I have tried this with pre-randomization i am getting the result but how to do by using constraint i am not getting that logic…
module check;
  class p;
    rand bit a = 1;
    bit [31:0] b = 2;  // this holds the count of sub-patterns'10'->(2),'1100'-> (4),'111000'-> (6) etc. Increment by 2 					   // once count matches b value which means sub-pattern is done
    bit [31:0] count = 0; // Every time pattern matches reset the count to '0'
    constraint a_size { if(count == b) a == 1;
                        else if(count == b/2) a == 0;
                        else a == const'(a);   }
      if(count == b) begin
        b += 2;
        count = 0;
      count += 1;
    p p1 = new;
    repeat(30) begin
      void'(p1.randomize());
      $display(" a value : %0b",p1.a);
//output :
# run -all
#  a value : 1
#  a value : 0
#  a value : 1
#  a value : 1
#  a value : 0
#  a value : 0
#  a value : 1
#  a value : 1
#  a value : 1
#  a value : 0
#  a value : 0
#  a value : 0
#  a value : 1
#  a value : 1
#  a value : 1
#  a value : 1
#  a value : 0
#  a value : 0
#  a value : 0
#  a value : 0
#  a value : 1
#  a value : 1
#  a value : 1
#  a value : 1
#  a value : 1
#  a value : 0
#  a value : 0
#  a value : 0
#  a value : 0
#  a value : 0
# exit
hope this helps.
that’s not working for me,actually. Could you simulate and let me know whether it’s working or not?
Interesting sequence. I tinkered with it a bit, noted its “square-root-ness”, but didn’t find the closed form. So, I looked it up on https://oeis.org/.
  // Write a constraint to generate a pattern
  //    1, 0, 1, 1, 0, 0, 1, 1, 1, 0, 0, 0, 1, 1, 1, 1, ....
  // ref: https://oeis.org/A118175
  class A118175;
    int unsigned n;
    rand bit value;
      value = $floor($sqrt(n + 1) + 0.5) - $floor($sqrt(n));
      ++n;
    function void print();
      $display("%0d", value);
  A118175 gen = new;
    repeat(20) begin
      gen.randomize();
      gen.print();
It’s one of the alternate solution which I have posted above but we have to solve this by using constraint…
Very fewer chances that we might make it only with constraints. For now i see this pattern requires randomize callback hooks. Will update if any with only constraints.
Its working for me. Try with siemens simulator.
Some simulators might give you the error for const’() as most simulators do not implement this from constraints point of view i feel.
ok sure…
It’s working for seimens…
Here is one way to do it without pre_randomize(), post_randomize(), const’() cast.
package learning;
 import uvm_pkg::*;
`include "uvm_macros.svh"
class packet extends uvm_object;
  `uvm_object_utils(packet)
  function new(string name = "packet");
    super.new(name);
  rand bit temp[][];
  rand bit arr[];
constraint seq {
    temp.size() inside {[2:10]};
    foreach (temp[i]) {
      temp[i].size() == (i+1)*2;
      foreach (temp[i][j]) {
        (j <= i) -> temp[i][j] == 1;
        (j >  i) -> temp[i][j] == 0;
    arr.size() == (temp.size()) * (temp.size()+1);
      foreach (temp[i,j]) {
          arr[(i*(i+1)) + j] == temp[i][j];
  virtual function void printInfo();
      `uvm_info(get_type_name, $sformatf("%p", arr), UVM_LOW)
class test extends uvm_test;
  `uvm_component_utils(test)
  rand packet pkt;
  function new (string name = "test", uvm_component parent);
    super.new(name, parent);
    phase.raise_objection(this);
    super.run_phase(phase);
      pkt = packet::type_id::create("pkt");
      repeat (30) begin
        pkt.randomize();
        pkt.printInfo();
    phase.drop_objection(this);
endpackage : learning
module top();
  import uvm_pkg::*;
  import learning::*;
    run_test("test");
Good solution!
I have tried this solution. Seems to be working.
Code:
module tb;
class test;
rand int a[];
int x=0,i=0;
constraint c {a.size==20;}
  while(i<$size(a))
      for(int j=0; j<=x; j++)
        	a[i]=1;
          	i++;
        	a[i]=0;
          	i++;
      x++;
test h;
initial
h=new;
h.randomize;
$display(“a=%p”,h.a);
Output:
a='{1, 0, 1, 1, 0, 0, 1, 1, 1, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 0}
I have tried it using 2 dimensional dynamic array. -->10110011100011110000…
class packet;
   rand bit arr[ ][ ];
   constraint c1{arr.size==5;}
   constraint c2{foreach(arr[i]){
     arr[i].size==(2+(i*2));
     foreach(arr[i,j])if(j<=i)arr[i][j]==1;
                      else arr[i][j]==0;}}
module gen_pattern;
  packet p;
    p=new();
    p.randomize();
    foreach(p.arr[i,j])$write("%0d ",p.arr[i][j]);
