class foo;
rand bit a;
rand int x;
constraint c_test
x >= (1 + a);
x <= 10;
module tb;
foo bar = new;
repeat(10) begin
bar.randomize();
$display("bar.x = %0d", bar.x);
If I am running above code I am getting negative numbers for the bar.x,
bar.x = -2088208539
bar.x = -215028475
bar.x = -498680303
bar.x = -574691074
bar.x = -896506966
bar.x = -1472970799
bar.x = -1343312610
bar.x = -1944336458
bar.x = -2003895586
bar.x = -687962719
looks like there is some issue with constraint solver, due to fact that the value X is constrained based on a, where x is type of int and a is a type of bit.
if I am using casting operator (like x >= int’(1 + a);) the behavior looks okay.
Just wondering does the types are getting consider while solving the constraint.. Can anyone help me on the root cause behind this?
