Constraint solver failed when accessing a null array
I’m trying to constrain a scatter gather list as shown below.
But the C_SET_LENGTH_FIELD constraint causes this error in VCS.
Error-[CNST-NAE] Constraint null array error
The constraint solver failed when accessing a null array
sgl__vcs_type[5].idx.
Please make sure array sgl__vcs_type[5].idx is allocated properly.
The number of elements gets randomized to 5 (0 to 4), but the solver wants to looks at the non-existent element 5 to satisfy the constraint which fails.
How can I create a guard to prevent this?
Regards,
Dale.
class cmd_item extends uvm_sequence_item;
    // UVM automation macro
    `uvm_object_utils(cmd_item)
    rand byte sgl[][][16];
    constraint C_NUM_ELEMENTS {sgl.size inside { [5:7] }; }
    constraint C_NUM_DESCRIPTORS_PER_ELEMENT {
        foreach (sgl[i,,]) {
            sgl[i].size inside { [1:10] };
    constraint C_SET_LENGTH_FIELD {
        foreach (sgl[i,j,]) {
            sgl[i][j][8] == sgl[i+1].size;
    function string sprint();
        string s;
        s = {s, $psprintf("\n[There are this many elements := %0d]\n", sgl.size())};
        foreach (sgl[i,])
            s = {s, $psprintf("[Segement %0d has this many descriptors := %0d]\n", i, sgl[i].size)};
        foreach (sgl[i,j])
            s = {s, $psprintf("[Segment := %0d, Descriptor := %0d, Length := %0d]\n", i,j, sgl[i][j][8])};
        return s;
  cmd_item c=new();
   initial repeat(1) begin
      assert(c.randomize());
      uvm_report_info("cmd_item", c.sprint());
In reply to dshanley:
Issue is when I == 4,I + 1 you’ve on last constraint goes out of range. So VCS is right here. What would you want the value to be for last iteration? Once you decide that you can use an implication as guard as in:
i < sgl.size → …
HTH
Srini
www.verifworks.com
In reply to Srini @ CVCblr.com:
Hi Srini,
Thanks for your help.
I’ve added an implication to avoid the out of range issue.
As follows,
            (i <= sgl.size-2) -> (sgl[i][j][8] == sgl[i+1].size);
                                 (sgl[i][j][8] == 0);
But now I get a “Constraints inconsistency failure”.
Solver failed when solving following set of constraints
rand bit[30:0] sgl__vcs_type[1].idx.size() = 31'h9; // rand_mode = OFF
rand bit signed [7:0] sgl__vcs_type[0].idx[4].idx[8]; // rand_mode = ON
constraint C_SET_LENGTH_FIELD    // (from this) (constraint_mode = ON) (../tb/for_va_question.sv:29)
   (sgl__vcs_type[0].idx[4].idx[8] == sgl__vcs_type[1].idx.size());
   (sgl__vcs_type[0].idx[4].idx[8] == 0);
Why is the solver trying to solve both sides of the implication operator when i == 0?
Regards,
Dale.
Can you share the standalone test that VCS creates in such case? I don’t recall if it is by default or under +ntb_solver something (please look in VCS -doc if needed)
Regards
Srini
One more quick Q - do you need byte (signed 8 bits) or unsigned 8 bits?
Because, solver is getting two opposite choices, i) because of implication, ii) there is no restriction for second choice.
When there is no implication solver will consider it always. In your case which is contradictory with implication.
A solution:
            (i ==sgl.size-1) ->  (sgl[i][j][8] == 0); // This is application only for last element.
conflict error is correct…
foreach (sgl[i,]) {
sgl[i].size inside { [1:10] }; // #1_1 it is non-zero size…
(i <= sgl.size-2) → (sgl[i][j][8] == sgl[i+1].size);// #1_2 it is non-zero size
(sgl[i][j][8] == 0) // #2_1 it tries to set ‘zero’
because of these two sets of constraints
#1_1, #1_2 // which tries to set sgl[i][j][8] to a non-zero value
#2_1 // which tries to set sgl[i][j][8] to ‘zero’.
we see the conflict…
Hi Srini,
I need unsigned bytes.
Dale.
In reply to prashant.kaushik:
Thanks, I tried your suggestion as below, but it results in my original error which was a “Constraint null error array”
    rand byte unsigned sgl[][][16];
    constraint C_NUM_ELEMENTS {sgl.size inside { [5:5] }; }
            sgl[i].size inside { [5:10] };
            (i == sgl.size-1) -> (sgl[i][j][8] == 5); // This is application only for last element.
        string s;
        foreach (sgl[i,])
        foreach (sgl[i,j])
        return s;
  cmd_item c=new();
…/tb/for_va_question.sv, 61
“…/tb/for_va_question.sv”, 61: top.unnamed$$_1: started at 0ps failed at 0ps
Offending ‘c.randomize()’
UVM_INFO @ 0: reporter [cmd_item]
[There are this many elements := 5]
[Segement 0 has this many descriptors := 5]
[Segement 1 has this many descriptors := 9]
[Segement 2 has this many descriptors := 10]
[Segement 3 has this many descriptors := 8]
[Segement 4 has this many descriptors := 10]
In reply to vinod cheedella:
I don’t think that this is my issue, as neither #1_1, or #1_2 constrain the inner dimension to have a non-zero value.
Dale.
Hi Srini,
Dale.
I guessed so, do you realise byte in SV is “bit signed [7:0]”
Please try changing the data type, if you show VCS standalone test for this failure I can assist further, feel free to email via srini@cvcblr
Srini
try it with a intermediate variable ‘sgl_arr_size’, then it seems to be working…
import uvm_pkg::*;
rand bit [7:0] sgl_arr_size;
    sgl_arr_size == sgl.size;
        (i <= sgl_arr_size-2) -> (sgl[i][j][8] == sgl[i+1].size);
        (i == sgl_arr_size-1) -> (sgl[i][j][8] == 5); // This is application only for last element.
    string s;
    foreach (sgl[i,])
    foreach (sgl[i,j])
    return s;
cmd_item c=new();
My example is working with Questa 10.4. So it seems me there is a tool issue.
[i]In reply to
string s;
foreach (sgl[i,])
foreach (sgl[i,j])
return s;
cmd_item c=new();
The above code looks fine and runs fine on other tools as well. Can you double check VCS result? If problem still persists, time to contact your vendor!
HTH
Srini
www.verifworks.com
