I have array of uvm_object say a[4]
class a;
rand int mod_size[];
rand int trans_cnt;
constraint mod_size_constr{
mod_size.size == trans_cnt;
constraint trans_cnt_constr{
trans_cnt == 10; by default it is 0 in main class. in test case i have it constrianted to 10 here.
I get solver error for array size for mod_size really big even though I have constraint to have it equal to the trans_cnt
Can you help to understand why I get the solver error.
I modified my solver error message to keep confidentiality of my structure… Hope you can still understand what the error is.
Solver failed when solving following set of constraints
rand integer a[4].progressive_mode = 1; // rand_mode = OFF
rand integer a[4].trans_cnt; // rand_mode = ON
rand bit[30:0] a[4].vfp_mod.size() = 31'h15958e2; // rand_mode = OFF
constraint dyn_rr_base_constr // (from a[4]) (constraint_mode = ON)
(a[4].vfp_mod.size() == a[4].trans_cnt;
a[4].trans_cnt == 20;
Kanmani S
