I happened to come across this constraint example on the internet.
There is a signal wdata[63:0] representing data-bus
There is a signal wstrb[7:0] representing strobe/valid byte of the data-bus
Constraint is when a valid byte is present in wdata, it has to be either 8’b11111111 or 8’b10101010
Write a SV code/constraint to generate suitable transactions
class Example;
rand bit[7:0] wstrb;
rand bit[63:0] wdata;
rand bit [7:0] valid_byte;
constraint c0{valid_byte inside {8'b11111111, 8'b10101010};}
constraint c2{foreach( wstrb[i])
wstrb[i] inside {0,1};};
constraint c1{foreach(wstrb[i]){
(wstrb[i]) -> wdata[8*i+:8] inside {valid_byte};
constraint c4{solve wstrb before wdata;}
module TB;
Example E;
E = new();
repeat(10) begin
assert(E.randomize());
$display("wdata = 0x%x, wstrb = %b", E.wdata, E.wstrb);
If I don’t have “solve wstrb before wdata”, then wstrb remains zero (for all 10 randomizations I did).
Does that mean, the constraint solver needs to be specifically told of the order? If I didn’t specify the order, can it go either ways?
Appreciate any feedback. Thanks much!
