Constraint for randomization
I have 2 random variables a,b.
But a should appear 10 times frequently as b.
How do I write this constraint?
Thanks & Regards,
Gurumoorthy
In reply to GURUMOORTHY:
Are you crating new object every time when you randomize it or you randomizing same object 10 times ??
If you randomizing same object you can use following code.
class xyz;
rand int a,b;
int i =0 ;
constraint ab_c {if(i <10 ) (b==a);}
function post_randomize()
i = i+1 ;
If you are creating object before each randomization then
class xyz;
rand int a,b;
static int i =0 ;
i = i+1 ;
In reply to Chandra Bhushan Singh:
creating new object actually.
can you tell way to do that for the one with different object and also for randomizing same object.
[i]In reply to Chandra Bhushan Singh:[/s
I am sorry, I couldn’t see the solutions since my page was not refreshed. Thanks very much for your help.
hi,
what does this mean?
especially b==a?
This mean a and b is equal for first 10 randomization.
equal in the sense. Values must be different. They should be random values.
a and b is declared as random so it takes random vales but for first times its equal.
Hi GURUMOORTHY,
Could you elaborate more on “a should appear 10 times frequently as b.”?
It is better if you can specify here a sample output (that you are expecting post randomization).
a and b should be independent of each other.
But random variable generation constraint should be frequency of randomization of variable b must be 10 times slower when compared to that of a.
We can use rand_mode() function to switch off the randomization of a particular random variable inside the class before actually randomizing it.
Hope the following code helps to meet your requirement.
class xyz;
  rand int a,b;
xyz xyz_h = new();
int i = 1;
while(i)
  if(i%10 != 0) begin
    xyz_h.a.rand_mode(0); // switch off the randomization on variable 'a'.
    xyz_h.randomize(); // Only 'b' gets randomized.
    xyz_h.a.rand_mode(1); // switch on the randomization on variable 'a'.
  end else begin
    // Randomizing 'a' only after ten times
    xyz_h.randomize();  // both a, b gets randomized
  i++;
In reply to S.P.Rajkumar.V:
This is more suitable I guess.
