Constraint for a value range not inside a value range
Thanks Dave for the solution.
I modified the code a bit.
module top();
bit [7:0] range_of_values[$];
class packet;
   rand bit [7:0] a;
   rand bit [2:0] s;
   function void post_randomize;
      for(int ii=a; ii<=a+s; ii++)
	range_of_values.push_back(ii);
   constraint no_overflow { 8'(a+s) == int'(a+s);}
endclass : packet
initial
  packet pp;
  pp = new();
  pp.randomize() with { // pp.a != 5 &&
                        foreach(range_of_values[ii])
                              !(range_of_values[ii] inside {[a:a+s]});
The above code works.
If I uncomment the part “pp.a !=5 &&” I see compile error
** Error: (vlog-13069) aa.sv(23): near “foreach”: syntax error, unexpected foreach.
Let me know how to avoid it.
Sunil.
