write a constraint to generate prime numbers between the range of 1 to 100?
Take a look at this previous question:
https://verificationacademy.com/forums/systemverilog/prime-numbers-constraint
This example also has a scecondary contraint that the number must contain a 7, which you would not need.
class prime_numbers;
rand int unsigned prime[];
constraint const_prime {prime.size inside{100};
foreach(prime[i])
if (i>1 && (!((i%2==0 && i!=2) || (i%3==0 && i!=3) || (i%5==0 && i!=5) || (i%7==0 && i!=7))))
prime[i]==i;
prime[i]==2;
function void post_randomize;
prime = prime.unique();
module tb();
prime_numbers pm;
initial
pm=new();
assert(pm.randomize());
$display("the prime: %p",pm.prime);
Check this code.It may help you.
class cons;
rand int a;
int b;
// range constraint
constraint range { a inside {[1:100]}; }
// call function inside constraint
constraint prime_c { prime(a); }
// function to check prime
function bit prime(int x);
if(x <= 1)
return 0;
for(int i=2; i<x; i++) begin
if(x % i == 0)
return 0;
return 1;
b = a;
$display("Prime number is %0d", b);
cons c;
c = new();
repeat(20) begin
assert(c.randomize());
