I have below constraint code example:
constraint c_ccs_index {
ccs_index inside {[0:(state.ccs_buffer_q[ccs_buffer_index].ccs_num - 1)]};
constraint c_size {
size == state.ccs_buffer_q[ccs_buffer_index].ccs_q[ccs_index].data_q.size();
State is a global handle, and ccs_buffer_index is input.
I make sure ccs_buffer_q is already generated before solving above constraint.
But VCS reports a run-time error:
Error-[VNST-AICUE] Constraint array index cyclic unsolvable error
The solver will not solve for array ‘state.ccs_buffer_q[0].ccs_q’ indexed by random variable ‘[ccs_index]’.
The solving of the random index is dependent on the random array itself.
Please try to modify the constraints including the index variable.
Why does this constraint error come out?
