Hi All,
I want to constraint an array / a queue to have at least n pairs of consecutive x values.
For example:
int values = '{1,2,2,3,5,1,2,2,2};
In the above array (1,2), (6,7), (7,8) index pairs have value “2”. So there are 3 pairs of value “2”.
I want to constrain this number of pairs to a specific value.
I expect something like below, (generated from Bard and modified: not syntactically correct)
rand int values[10];
constraint values_c{
int pair_count;
foreach (values[i]) {
if (i < values.size()-1) {
if (values[i] == 2 && values[i+1] == 2) {
pair_count ++;
pair_count == 3;
Could someone please explain me how to implement the above constraint?
Thanks in advance.
In reply to tharindu:
Constraints are not procedural code, they are equations.
Although you might be able to get this into a single sum() equation, using a helper array ‘pairs’ i think is easier to comprehend.
class A;
rand int values[10], pairs[10];
int pair_count = 3;
int selected_value = 2;
constraint values_c {
foreach (values[i])
if (i > 0) pairs[i] ==
(values[i-1] == selected_value && values[i] == selected_value);
pairs[0] == 0;
pairs.sum() == pair_count;
A a = new;
initial repeat(10) begin
assert(a.randomize);
$display("%p",a.values);
$display("%p",a.pairs);
Hey Dave,
I tried with the sum() function:
class Example;
rand bit[4:0] num_arr[10];
rand int x;
rand int n_pairs;
constraint c1 {x inside [{2:4}];}
constraint c2 {n_pairs inside {[3:4]};}
constraint c3{foreach(num_arr[i]){
i <=8 -> num_arr.sum (with (num_arr[item.index-1] && num_arr[item.index] == x)) == n_pairs;
}}; //index out of bounds error although I have i <= 8; why?
module TB;
Example E;
E = new();
assert(E.randomize());
$display("%p", E.num_arr);
endmodule```
It looks like i<=8 does not kick in for the c3 constraint; also, sum() applies to ALL elements of the array and cannot be selective? Experimenting and trying to understand. Appreciate your inputs. Thank you.
Two problems with your constraint c3
- i iterates from 0 to 9. You either need to change the condition to
i>0 or the use index+1 instead of index-1.
- The result of a logical and (
&&) has bit width of 1, so the sum is only 1-bit wide. You need to cast it to a larger width.
constraint c3{foreach(num_arr[i]) i <=8 ->
num_arr.sum() with (
int'(num_arr[item.index+1]==x && num_arr[item.index] ==x)
= n_pairs;
