Constraining the Sum of Even Indices of an array
Hi All,
Is it possible to constraint the sum of even indices of an array to certain fixed value(In this example sum of even array indices should be 100).
Performing sum of an even array indices by below logic.
 a.sum() with (((32'(a[item.index]))%32'h2) == 32'b0);
Code :
  class mem;
    rand bit[7:0] a[];
    rand bit[7:0] s;
    constraint array_c {
      a.size() == 10;
      constraint c_sum { s == a.sum() with (((32'(a[item.index]))%32'h2) == 32'b0);  // Performing sum only on even index
        s <= 100;  // constraining sum to 100.
     foreach(a[i]) begin
       $display("********************************************************");
       $display("a[%0d] =%0d",i,a[i]);
  mem mm;
  bit succ;
    mm = new();
    repeat(1) begin
      succ = mm.randomize();
I am getting below thing as output.
a[0] =139
a[1] =75
a[2] =3
a[3] =195
a[4] =211
a[5] =57
a[6] =53
a[7] =158
a[8] =35
a[9] =255
quit -f
Could anyone help me to solve this issue.
In reply to Tulasiram:
Your constraint should be
 constraint c_sum { s == a.sum() with (item.index%2 ? 0 : item);  // Performing sum only on even index
        s == 100;  // constraining sum to 100.
