I have 2D unpacked array :
class A;
rand bit arr [8][8];
// Absolute value
function int abs(int val);
return val >=0 ? val : -(val);
constraint UNIQ_ROW {
foreach( arr[i] )
arr[i].sum() with ( int'( item ) ) == 1 ;
// column sum == 1
constraint col {
foreach (arr[r1,c1])
foreach(arr[r2,c2])
( (c1 == c2) && (r1 != r2) && arr[r1][c1]==1 ) -> ( arr[r2][c2] == 0 );
constraint diag { foreach (arr[r1,c1]) foreach (arr[r2,c2])
( ( abs(r1-r2) == abs(c2-c1) ) && r1!=r2 && c1!=c2 && arr[r1][c1]==1 ) -> ( arr[r2][c2] == 0 ) ;
The diagonal constraint ensures that if an element is 1 , all it’s respective diagonal elements would be 0
My question is whether there is an alternative to diagonal constraint using array reduction method : sum() ?
