Constrained randomization
Hi Experts,
I am new to UVM. Just started working on it. I have the following query on randomizing variables defined in sequence class from the test. Please help on this.
class sample_sequence extends uvm_sequence();
rand int num_seq;
`uvm_object_utils_begin(sample_sequence )
	`uvm_field_int(num_seq, UVM_ALL_ON);
`uvm_object_utils_end
//code for sequence generation
endclass: sample_sequence
How do i randomize variable num_seq from the test before invoking this sequence??
Thanks for your inputs in advance.
In reply to chethan2807:
You call randomize() before starting it in your test.
task my_test::run_phase(uvm_phase phase);
   seq = simple_sequence::type_id::create(...);
   if (!seq.randomize()) `uvm_fatal("RANDOMFAIL","Could not randomize sequence");
   seq.start();
Thank you so much for the answer. If i understood correctly seq.randomize() will randomize the entire sequence, what if i want to randomize any particular variable defined in the sequence rather all??.
Probably not a good idea, but you have three choices:
  1. Use rand_mode(0) to turn of the random variables you do not want randomized
  2. using seq.randomize(num_seq) will randomize just num_seq, all active constraints are still considered.
  3. using std::randomize(seq.num_seq) will randomize just num_seq, only the constraints provided using the with{} clause are considered.
I say this is not recommended because once you start randomizing class variables one at a time, it becomes difficult to randomize the entire class and preserve the previously generated random variables.
Thank you very much for the detailed explanation.
My intention is not to randomize any of the transaction item variable from a test case rather, I was trying to control number of sequence to be generated from a test by randomizing the variable defined inside a sequence.
Here is what i meant. sram_test → sram_sequence → sram_transaction
class sram_test extends sram_base_test;
  sram_sequence sram_seq;
  `uvm_component_utils(sram_test)
  function new(input string name="sram_test", input uvm_component parent=null);
      super.new(name,parent);
    super.build_phase(phase);
    sram_seq = sram_sequence::type_id::create( "sram_seq", this);
	uvm_config_db#(int)::set(this,"sram_ev.sram_agt.monitor", "check_enable", 1);
	uvm_config_db#(int)::set(this,"sram_ev.sram_agt.sram_seqr", "num_seq", 5);
	endfunction : build_phase
  task run_phase (uvm_phase phase);
     `uvm_info(get_type_name(), "Running sram_test ...", UVM_MEDIUM)
     phase.raise_objection(this);
	 sram_seq.randomize()
     sram_seq.start( sram_ev.sram_agt.sram_seqr);
     #1ns;
     phase.drop_objection(this);
     `uvm_info(get_type_name(), "sram_test end ", UVM_MEDIUM)
endclass: test
class sram_sequence extends uvm_sequence# (sram_transaction, sram_transaction); //request and response types
	rand int item_cnt;
	`uvm_object_utils_begin(sram_sequence)
	`uvm_declare_p_sequencer(sram_sequencer);
	function new(string name ="sram_sequence");
		super.new(name);
	virtual task body();
		uvm_config_db #(int)::get(p_sequencer,"","num_seq",num_seq);
		`uvm_info(get_type_name(),  $sformatf("number of sequences to be generated = %d", num_seq), UVM_MEDIUM );
		repeat(item_cnt)
		`uvm_do(req);
	endtask : body
endclass : sram_sequence
class sram_transaction extends uvm_sequence_item;
	rand bit [9:0] Addr;
	rand bit [31:0] DataIn;
	bit [31:0] DataOut;
	rand bit WbCyc;
	rand bit WbStrb;
	rand bit WbWr;
	constraint addreslimit {Addr < 500; }
	constraint datanotzero {DataIn !='0;	}
	constraint WbCyc_range { WbCyc dist { [0:1]:/ 2 }; }
	constraint WbStrb_range { WbStrb dist { [0:1]:/ 2 }; }
	constraint WbWr_range { WbWr dist {0:=3, 1:=7 }; } //P(0) = 3/10 ; P(1) = 7/10
	`uvm_object_utils_begin(sram_transaction )
		`uvm_field_int(Addr, UVM_ALL_ON)
		`uvm_field_int(DataIn, UVM_ALL_ON)
		`uvm_field_int(WbCyc, UVM_ALL_ON)
		`uvm_field_int(WbStrb, UVM_ALL_ON)
		`uvm_field_int(WbWr, UVM_ALL_ON)
	function new (string name ="sram_transaction ");
		super.new(name); //super is referring to the base class constructor function
	endfunction: new
endclass : sram_transaction
Does this mean you don’t want to randomize ‘num_seq’ while randomizing all other data mebers of your seq_item?
BTW in your sram_sequence you have to declare num_seq, either in the class or in the body method.
