In reply to ssureshg_:
In reply to muneebullashariff:
I am not seeing any constraint conflicts. I changed the code a little, as below
module tb;
class sum_array;
rand int unsigned arr[];
constraint arr_c { arr.size() == 4;
foreach(arr[i]) { (arr[i]%8) == 0; } }
constraint sum_c { arr.sum() with (36'(item)) == 36'h0_0000_0028 ; } //hex equivalent of dec 40
//added extra bits to make sure, it is the sum that is 40, not the sum after overflow
initial
sum_array c1;
c1 = new;
void'(c1.randomize());
$display("%p",c1.arr);
I see following output over diff runs
'{'h18,'h8,'h8,'h0}
'{'h0,'h0,h28,'h0}
'{'h0,'h28,'h0,'h0}
'{'h0,'h8,'h20,'h0}
Hi,
Many thanks for your reply.
The above mentioned solution is working perfect with questa and Synopsis tools.
The constraint conflict is seen in Cadence tool.
I am puzzled with this behavior!
Thank you,
Regards,
Muneeb
