Const variable assignment
Hi All,
According to systemverilog LRM,
An Instance constants do not include an initial value in their declaration, only the const qualifier. This type of constant can be assigned a value at run-time, but the assignment can only be done once in the corresponding class constructor.
class A ;
const int i  ;
function new();
i = 20;
i++;
i = 40;
In the above case , assignments to the constant variable is done more than one time and I am getting final output i=40 (questasim), which is wrong as per LRM.
Please clarify, if I have missed something .
Regards,
Abhijeet
In reply to abhijeet Sahoo:
Would you please provide a reference from SV LRM for “This type of constant can be assigned a value at run-time, but the assignment can only be done once in the corresponding class constructor”.
In reply to prashant.kaushik:
It seems me Questa is upgraded. I tried with questa 10.4 and do not get error.
However, tried in edaplay ground and VCS is throwing compilation error for ‘re initialization’ of ‘const’ class property.
Section 8.19 Constant class properties of the 1800-2012 LRM
