In reply to Thomas Kruse:
This refers the the default clause in an assignment pattern. Let’s say you had a struct with three elements
module top;
typedef struct {bit [3:0] a; bit [7:0] b; bit [15:0] c;} ab_t;
ab_t ab;
ab = '{a: ~1'b0, default:~1'b0};
$displayh("%p",ab); // #
Normally each elements gets assigned in the context of the assignment to an individual field type. For field expression a:~1’b0, the operand 1’b0 gets extended before applying the operator, so the result is 4’b1111. But the default applies to fields ‘b’ and ‘c’ of different type. The expression ~1’b0 gets evaluated in a 1-bit context, becoming 1’b1, and afterwards gets 0-extended to the size of fields b and c.
I believe the part about a static cast not be considered as being part of an assignment-like context is a mistake in the LRM. I filed an errata.
