Hi All,
Please advice the following;
/////// RTL/////////
module rtl_block();
input logic rtl_in1;
output logic rtl_out1;
/////// INTRFACE/////////
interface example_intf;
logic intf_in1;
logic [4-1:0] int_out1;
endinterface
/////// TOP MODULE /////////
module top_tb;
logic tb_in1;
logic [4-1:0] tb_out1; //line1
example_intf i_intf[4] (..clk, ..rst ...);
assign tb_out1[0] = i_intf[0].int_out1; //line2
assign tb_out1[1] = i_intf[1].int_out1;
assign tb_out1[2] = i_intf[2].int_out1;
assign tb_out1[3] = i_intf[3].int_out1;
rtl_block instance_rtl_block(
.rtl_in1(tb_in1),
.rtl_out1(tb_out1), //line3
Result:
code works fine for input connection. But it is giving error at line3, that is for output connection;
“Illegal combination of drivers”.
I changed at line1, from logic to wire, error fixed but not able to see the value at the interface. How can I fix this so that I should be able to see the value from both top module and interface level.
Also, tried at line2 by changing from assign to force, but received syntax error.
Regards,
Mahesh
