input hl_common_pkg::router_signals [1:0] lbw_rd_rq_struct;
assume i am declaring the above signal in my rtl and below is the definition of the package.
struct packed {
logic [40:0] payload;
[4:0] ch_header;
}router_signals ;
so considering above declarations, can i assign like below for the connections(driving values form my testbench)…?
assign dut.lbw_rd_rq_struct.payload[4] = 1'b1;
assign dut.lbw_rd_rq_struct.payload[5] = 1'b0;
and so on..
can we assing individually like this..?
as i got below errors:
**Error-[PC_VIPCBD] Variable input ports cannot be driven**
** Variable input ports cannot be driven**
The code you wrote should not have produced that error assuming you meant to declare ch_header
with a logic
datatype. input
ports declared with a 4-state packed logic
type are implicitly wire
signals, not variables. That is a tool issue. You could declare it explicitly with
input wire hl_common_pkg::router_signals [1:0] lbw_rd_rq_struct;
But there are a number of other problems.
It’s legal to have multiple continuous assignments to wires. However, your hierarchical references are not valid. it should be
dut.lbw_rd_rq_struct[0].payload[4]
dut.lbw_rd_rq_struct[1].payload[4]
But you probably want a force
instead of a assign
so that the 1 and 0 values are not in contention with other drivers on the input.
force dut.lbw_rd_rq_struct[0].payload[4] = 1'b1;
force dut.lbw_rd_rq_struct[0].payload[5] = 1'b0;
hi dave,
sorry for the sytanx error, whatever you said is correct.
when i am using below
assign dut.lbw_rd_rq_struct[0].payload[4] ='1b1;
assign dut.lbw_rd_rq_struct[0].payload[5]=1’b1;
it is throwing the error but when i am using the force then it is not throwing the errors.
