Hi all,
We can use same set of registers in multiple uvm_reg_maps by adding same registers to each map with different base address. So that we can use same adapter, sequencer and driver to generate write/read sequence for each register but through different map by using write/read function by passing proper map argument.
How can I use a single uvm_reg_predictor for multiple uvm_reg_maps to snoop all the accesses with all map addresses? There is only one handle “map” in predictor.
Thanks in advance.
Regards,
Mani
