Connecting the port of the TB (UVM) and DUT(System Verilog)
Hi All,
I am connecting the ports of my testbench which is written in UVM and my DUT which is in System verilog.
the way I am connecting is as below:
scheduler_top sch(.clock(clock),
.reset(reset),
.header(in0.header),
.addr(in0.addr),
.data(in0.data),
.rw_en(in0.rw_en));
I am getting few warnings as :
ncelab: *W,CUVMPW (./top_dut.sv,30|37): port sizes differ in port connection (8/1).
.addr(in0.addr),
ncelab: *W,CUVMPW (./top_dut.sv,31|33): port sizes differ in port connection (29/1).
.data(in0.data),
ncelab: *W,CUVMPW (./top_dut.sv,32|33): port sizes differ in port connection (64/1).
I have used structure data types in my DUT and connecting with the top module as below:
module scheduler_top (input clock,
input reset,
//Core requests signals
input header,
input addr,
input data,
input rw_en);
assign cpu_in[101:94] = header;
assign cpu_in[93:65] = addr;
assign cpu_in[64:1] = data;
assign cpu_in[0] = rw_en;
This is how my structure looks like
typedef struct packed{
logic [7:0] header;
logic [28:0] addr;
logic [63:0] data;
logic rw_en;
}cpu_req_type ;
But ‘x’ is propagated throughout my dut. It is not taking the values which is send by the testbench.
Any suggestions are welcome.
Leela
Well, you haven’t shown what ‘in0’ is, but it looks like you’ve declared your core requests signals in schedule_top to be single bits, but your struct defines them as vectors. Your assign statements would leave the MSBs as ‘x’ since you’re not assigning them to anything. Try fixing your declarations and see if that helps.
In reply to tfitz:
I changed the declarations and it worked… thanks a lot for your help.
Regards,
Leela
