The `uvm_analysis_imp_decl() macro defines the analysis imports in the scoreboard. If you desire multiple imports, you declare and instantiate each port with a unique name.
When you connect an analysis port, you use the ‘write’ function to send the data from the analysis port to the analysis_import. You don’t add the unique name to the write function call.
In your case, you are connecting ‘sender’ to both analysis imports, so both write functions (write, write_BEFORE will be called with the same item.
I intend to create my own write function in the scoreboard apart from the write method. what ever you mentioned its correct only and I followed the same way to create my own imp . please check this code Edit code - EDA Playground
help me to find why the error is coming even after I followed all the steps mentioned above
I dont think it will work.
send_port is a variable of type uvm_analysis_port which doesn’t have write_BEFORE method. It only has write method.
In your case, since you have multiple monitors, each monitor instances’ send_port can call their respective write method. when you are connecting it with scoreboard, you can connect it with different IMPLEMENTATION port.
it dont have the write_BEFORE method i agress . I mentioned Cleary my intention is to create one method as per here mentioned (visit my initial attachement) . if i used write method for two monitor nee to implement two same write method inside scoreboard ?
