Confusion regarding range within inside operator
Hi All,
Consider the following code
bit [47:0] addr;
 parameter AXI_BASE_ADDR = 32'h1504000;
   repeat(5)
      if(! std::randomize(addr) with { addr inside {[AXI_BASE_ADDR:'h115_4FFF],['h150_0000:'h17F_FFFF],['h190_0000:'h19F_FFFF]}; }) $error("Randomization Failed");
      $display("addr is 0x%0h",addr);
I observe that ‘addr’ is never constrained to value in the 1st range [AXI_BASE_ADDR:'h115_4FFF],
why is it so ?
(2) On adding another inline constraint ( addr == 'h115_4FFF )
   repeat(5)
      if(! std::randomize(addr) with { addr inside {[AXI_BASE_ADDR:'h115_4FFF],['h150_0000:'h17F_FFFF],['h190_0000:'h19F_FFFF]}; addr == 'h115_4FFF; }) $error("Randomization Failed");
Why do I observe constraint failure ?
Also the error message across different tools is interesting
//  Error message from Tool1
Solver failed when solving following set of constraints
rand bit[47:0] addr; // rand_mode = ON
constraint WITH_CONSTRAINT    // (from this) (constraint_mode = ON) (testbench.sv:10)
   (addr inside {[32'h1504000:32'h1154fff], [32'h1500000:32'h17fffff], [32'h1900000:32'h19fffff]});
   (addr == 32'h1154fff);
There is no mention of the 1st range ( [AXI_BASE_ADDR:'h115_4FFF] ) within the inside operator
//  Error message from Tool2
 ** Error: Randomization Failed
    Time: 0 ns  Scope: tb File: testbench.sv Line: 12
 testbench.sv(12): randomize() failed due to conflicts between the following constraints:
 	testbench.sv(12): $inline { (addr inside { [48'h000001504000:48'h000001154fff], [48'h000001500000:48'h0000017fffff], [48'h000001900000:48'h0000019fffff] }); }
 Where:
 	addr = 48'h000001154fff
Tool2 does mention the 1st range, however it still gives conflict during randomization
The inside operator requires the range to be expressed in the format min:max. If min is greater than max, it is considered an empty match, meaning it cannot be matched. For instance, your min:’h150_4000’ is larger than your max:’h115_4FFF’.
So if I were to write only the high:low range, shouldn’t it be considered as if there is no constraint on addr ?
bit [47:0] addr;
   repeat(5)
      if(! std::randomize(addr) with { addr inside {[AXI_BASE_ADDR:'h115_4FFF] }) $error("Randomization Failed");
Can addr have any value from 0 to '1 ( all ones ) ?
No, then it would be an expression that could never be true.
