Hi all ,
I was going through Class Reference Manual 1.2 uvm_tlm_fifo_base
(I) get_ap :: Transactions passed via get, try_get, peek, or try_peek (via any port connected to the get_peek_export) are sent out this port via its write method.
But when I went through Library Code 1.2 I see that ::
get_ap.write(t) gets Called in for get() and try_get() Calls .
Even the Simulators Output match the library Code . I am confused regarding this .
class Component_fifo extends uvm_component ;
`uvm_component_utils(Component_fifo)
// We are creating a blocking TLM get port which will fetch a "simple_packet" type of data
uvm_tlm_fifo #(simple_packet) fifo ; // Constructed in build_phase
class ComponentB extends uvm_component ;
`uvm_component_utils(ComponentB)
uvm_blocking_get_port #(simple_packet) get_port; // Created in build_phase
simple_packet pkt;
function new (string name , uvm_component parent);
super.new(name, parent);
virtual task run_phase (uvm_phase phase);
forever
#5;
get_port.peek(pkt); // Doesn't call Subs2.write . Why ??
`uvm_info ("COMPB", "Packet peeked at CompB", UVM_LOW)
get_port.get(pkt); // Calls Subs2.write as Expected .
`uvm_info ("COMPB", "Packet received at CompB", UVM_LOW)
class Subs2 extends uvm_subscriber #(simple_packet) ;
`uvm_component_utils(Subs2)
endfunction: new
function void write(simple_packet t );
`uvm_info ("SUBS1", "Packet received at Subs1", UVM_LOW)
class my_env extends uvm_env;
`uvm_component_utils (my_env)
Component_fifo comp_fifo ; // Created in build_phase
Subs2 subs2; // Created in build_phase . Calls write()
ComponentA compA ; // Created in build_phase . Does the put()
ComponentB compB ; // Created in build_phase . Does the get()
virtual function void connect_phase (uvm_phase phase);
compA.put_port.connect (comp_fifo.fifo.put_export);
compB.get_port.connect (comp_fifo.fifo.get_peek_export);
comp_fifo.fifo.put_ap.connect ( subs1.analysis_export );
comp_fifo.fifo.get_ap.connect ( subs2.analysis_export );
Is this an issue in Library Code OR Class Reference Manual ?
(II) In uvm_tlm_fifo Class I see flush() Function Implemented as follows ::
virtual function void flush();
T t;
bit r;
r = 1;
while( r ) r = try_get( t ) ;
if( m.num() > 0 && m_pending_blocked_gets != 0 ) begin
uvm_report_error("flush failed" ,
"there are blocked gets preventing the flush", UVM_NONE);
I believe the try_get() Calls recursively till all elements are removed from Mailbox ( inside tlm_fifo ) .
My doubt is regarding the uvm_error’s Condition .
When would it be true ? i.e
m_num() is an int same as the size argument passed to new() and m_pending_blocked_gets is Simply a Counter that Increments on calls to get() and on getting a transaction decrements its count back to 0
Thanks in advance ,
ABD
