I can give you a example this may be very helpful to you.
class Base;
class child extends base ;
task display ();
$display(" This is true ");
module main ;
child my_child;
base my_base;
initial
my_child = new();
my_base = my_child;
my_child.display();
my_base.display();
RESULT :
The above code result in the ERROR.
Now i doing some modification :
class base ;
task display ();
$display(" This is again true ");
module main ;
child my_child;
base my_base;
initial
my_child = new();
my_base = my_child;
type_conv(my_base);
task type_conv(base my_base);
child ch;
$cast(ch,my_base);
ch.display();
RESULT :
This is again true
To access the variables and methods which are only in the subclass and not in the parent class, revert back the object to the subclass handle.AS the methods which are added in the subclasses which are not in the parent class can’t be accessed using the parent class handle.
