I am a beginner in UVM and trying to understand the purpose of uvm_void.
From the hierarchy, I see:
uvm_void
uvm_object
other UVM classes
But I am confused because uvm_void is an empty class with no methods or variables.
So my questions are:
If uvm_void is completely empty, then why was it needed?
Why didn’t UVM architects directly make uvm_object the top/base class?
What is the actual difference between uvm_void and uvm_object apart from one being empty and the other having methods?
What real problem does uvm_void solve?
In what situation would uvm_void work differently from uvm_object?
Is this only for framework architecture flexibility, or is there an actual practical use case?
As a beginner, it feels like uvm_object could also work everywhere, so I am unable to relate the need for uvm_void.
As a beginner or even average user, there’s no need to comprehend uvm_void. It’s worth noting that many people criticized the creation of the uvm_void class, considering it unnecessary overhead. This UVM class was introduced to address the limitation of SystemVerilog OOP, which originated from Java, in casting a pointer to a void* type, unlike in C/C++. This ensures that objects remain type-safe.
Java does have a root class java.lang.Object from which everything extends. uvm_void was designed to mimic this structure. It would primarily be used when integrating two different base class methodologies.
I have one more doubt regarding the use of uvm_void in UVM.
For example:
class uvm_pool #(type KEY=int, T=uvm_void) extends uvm_object;
virtual class uvm_port_base #(type IF=uvm_void) extends IF;
Why did UVM use uvm_void here instead of uvm_object?
What practical issue would happen if uvm_object was used instead?
When should a UVM class use:
Is uvm_void mainly used to allow non-uvm_object types/interfaces/classes as generic parameters?
I want to understand the architectural/design reason behind this choice.
uvm_void is redundant here because it will be overridden by any type including a non-class type. It’s unfortunate that there’s still a tool out there that doesn’t support parameters without a default assignment. This would force users to explicitly override the parameter when declaring a uvm_pool class
