Dear Forum,
We have a config class in the agent which contains test-bench configuration stuff and some settings given by user.
We also have sequence_item in the uvm.
My question is where it is better to put the some signals in config or in item.
For example where should we put the following items config or item:
a) error_inject_bits
b) crc or parity mode
c) coverage_enable
d) Start_time_for_data_sending after enable signal
These signals can be both user controllable or test-bench controllable.
