I am trying to randomize a variable in an object using inline constraint based on a condition. the variable of the condition is not a member of the object, but is a variable in the parent class from where randomization is called. The issue i am facing is that, while randomizing, the conditional statement is not honored, and inline constraint is not applied. Code snippet below.
class rand_obj;
rand bit test_value;
class test;
bit cond_flag = 1;
rand_obj obj;
//obj created
assert(obj.randomize() with
if(**cond_flag**) obj.test_value == 0;
else obj.test_value == 1;
In this above code, i am getting random values for test_value, while i am expecting for every time it should generate test_value == 0, since cond_flag is set.
Maybe you’ve something more in actual code. As such this looks fine. Maybe you are looking for local:: prefix that’s useful if you have cond_flag is in your obj_class as well.
Thanks… I went back to the code, and found issue in how “cond_flag” was set.
In this example, for the sake of simplicity i set the cond_flag in this class itself, but in real code, it was from a command line argument, which was actually not getting set properly.
Thanks Dave. Found the issue with command line argument not setting “cond_flag” properly. For the sake of simplicity, i set the “cond_flag” in the class itself, but in real code it was from command line. Issue resolved now.
I Will try to show a minimally complete code next time.
