Hi All,
How do I specify a conditional assertion based on p_event.
If p_event goes high , If a=0 and b=0 c should be equal to d
$rose(p_event) → if ((a=0) && (b==0)) |-> ( c == d);
JeffD
Hi All,
JeffD
property p0_c0_0;
@(posedge clk)
disable iff (!resetn)
($rose(p_event) && (a==0) && (b==0)) → (c == d);
a1: assert property(p0_c0_0);
is not working.
I even tried this one below. It is not working.
property p0_c0_1;
@(posedge clk)
$rose(p_event) |-> if ((a==0) && (b==0)) (c == d);
a1: assert property(p0_c0_1);
JeffD
In reply to dvuvmsv:
I experimented in edaplayground. it seems to be working
Thanks for the example. In my case p_event is generated from clk.
I do not see the assertion getting triggered.
property p0_c0_0;
@(posedge clk)
Do the assertion gets triggered if rising edge of p_event is generated from clk.
In your example p_event is independent of clk.
JeffD
The assertion is evaluated every raising edge of the clk.
And the antecedent is successful when there is raising_edge in p_event, a & b being zero.
JeffD
