Concatenation of 2 arrays
I have the following memeber in transaction:
bit [31:0] data [$];
The interface have the following input:
 logic [31:0] WDATA
In the driver I want to assign the concatenation of the transaction data to itself. For examle if the data contain FFFFFFFF, I havt to concatenate FFFFFFFF to FFFFFFFF, and then assign it to the virtual interface
pseudo code:
vif.DATA <= trx.data[i] (concatenation) trx.tata[i]
How can I do it?
In reply to saritr:
You can concatenate your data as follow:
vif.DATA <= {trx.data[i],trx.data[i]};
Your vif.DATA must be of 64 bits for full data reflection.
In reply to saritr:
Either you can use the replication operator.
// Assuming data[i] is 32 it wide vector and WDATA is 64 bit wide vector.
WDATA <= 2{data[i]};
Here is some info about replication operator.
In reply to sharvil111:
I did the following:
   int unsigned  j = (vif.WDATA.size())/2;
   vif.WDATA   <= j{axi_trx.data[i]};   //line 168
I got the following compilation error:
** Error: (vlog-13069) ** while parsing file included at ../sv/gr_ver_pkg
.sv(23)
** at ..\sv\axi_bfm.sv(168): near “{”: syntax error, unexpected ‘{’, expecting
In reply to saritr:
Forgot to keep a curly brace before replication iterator. Here is a working pseudo code:
module top();
  int j;
  bit [31:0] q[$];
  bit [63:0] data;
    q[0] = 'hABCD_1234;
    j=2;
    data = {j{q[0]}};
    $display("data = 0x%0x",data); // data = 0xabcd1234abcd1234
