BTW, I don’t recommend using the -mfcu switch - it makes it hard to break up your compilation into units that can be organized and compiled separately, forcing you to always compile your entire design in a single step. So called “incremental compile” features can save some time, but the compiler still has to access all your files to see what has changed.
For this issue, I think it would be really good to refer Dave’s post:
So, here once you define something in a package it is different than including a define directly. So compiler could not look for define macro which is defined inside the package. Please note the difference between referring something from package and using compiler define directives.
