Common uvm_sequence for multiple sequence_items
HI All,
one uvm_sequence parameterized with multiple sequence items.
For example,
class my_sequence1 extends uvm_sequence #(usb_seq_item);
class my_sequence1 extends uvm_sequence #(pcie_seq_item);
Is this allowed? If yes, could you please tell me the use case.
I tried to find example for this, but couldn't.
Thank you,
SystemVerilog does now allow two identifiers declared with the same name in the same scope. Doesn’t matter if the identifier is a class type or variable.
 class base_seq_item extends uvm_sequence_item;
   `uvm_object_utils(base_seq_item)
   function new(string name = "base_seq_item");
     super.new(name);
 class usb_seq_item extends base_seq_item;
   rand bit[7:0] data;
   `uvm_object_utils(usb_seq_item)
   function new(string name = "usb_seq_item");
     super.new(name);
 class pcie_seq_item extends base_seq_item;
   rand bit[15:0] addr;
   `uvm_object_utils(pcie_seq_item)
   function new(string name = "pcie_seq_item");
     super.new(name);
 class my_sequence1 extends uvm_sequence #(base_seq_item);
   `uvm_object_utils(my_sequence1)
   function new(string name = "my_sequence1");
     super.new(name);
   task body();
     base_seq_item item;
     repeat(5) begin
       if ($urandom % 2 == 0) begin
         item = usb_seq_item::type_id::create("usb_item");
       end else begin
         item = pcie_seq_item::type_id::create("pcie_item");
       start_item(item);
       assert(item.randomize());
       finish_item(item);
A uvm_sequence cannot be parameterized with multiple sequence item types directly, as it accepts only one type. To handle multiple types like usb_seq_item and pcie_seq_item, use a common base class (base_seq_item) for the sequence items. The sequence can then dynamically create and send either type of item based on runtime conditions.
Yes, Thank you for the example.
