I had raised a question in below post regarding clocking block. I got great inputs. I have updated my TB now.
Old post is here:
https://verificationacademy.com/forums/uvm/effect-clocking-block-uvm-driver/monitor
Sorry, now I am kind of stuck with some other issue. I have many other modules to be updated. So wanted to have a clear understanding before making any changes.
interface updn_counter_if(input logic clk, reset, clk_en);
logic [ABSOLUTE_DATA_WIDTH-1:0] count_value;
logic load_counter;
logic up_counter;
logic [1:0] inc;
logic [ABSOLUTE_DATA_WIDTH-1:0] current_value;
logic count_reached;
clocking counter_cb @(posedge clk);
default input #1step output #1;
inout load_counter;
inout count_value;
inout up_counter;
inout inc;
input current_value;
input count_reached;
endclocking
endinterface
DRIVER
virtual task drive();
@( counter_vif.counter_cb);
if (counter_vif.clk_en == 1 && counter_vif.reset) begin
counter_vif.counter_cb.count_value <= req.count_value;
counter_vif.counter_cb.load_counter <= req.load_counter;
counter_vif.counter_cb.up_counter <= req.up_counter;
counter_vif.counter_cb.inc <= req.inc;
end //if
MONITOR
super.run_phase(phase);
forever begin
@(counter_vif.counter_cb);
//@(posedge counter_vif.clk);
if (counter_vif.clk_en && counter_vif.reset == 1) begin
seq_item_collected.count_value = counter_vif.count_value;
seq_item_collected.load_counter = counter_vif.load_counter;
seq_item_collected.up_counter = counter_vif.up_counter;
seq_item_collected.inc = counter_vif.inc;
seq_item_collected.current_value = counter_vif.counter_cb.current_value;
seq_item_collected.count_reached = counter_vif.counter_cb.count_reached;
trans_collected_port.write(seq_item_collected);
end //
end //forever
endtask : run_phase
If i specify input skew in clocking clock to be zero, my data integrity looks fine. If i specify it to be non-zero, there is an offset of 1 value between RTL and TB.
- IS it because the RTL value is sampled just before the clock edge and takes the previous value? Do we update our TB accordingly?
- Should things change if input skew is zero amd non-zero? I mean, for non-zero it gets the value from previous clock?
- Do we have take any precautions while handling clk_en which is not part of clocking block?
Please let me know. Thank you!
