Normally, I used to generate clock in top module. But,now I have a separate driver for clocks generation. I use forever to generate clock. But,simulation is not exiting.Please suggest me how to create clock from driver and drives to interface.
I saw a similar example in verification academy:
task my_driver::clk_gen();
bit clk;
this.clk_en = 1;
forever begin
if (this.clk_en == 1)begin
#(`CLK_PERIOD); //This works !!!
clk = ~clk;
this.vif.tb_clk = clk;
endtask: clk_gen
I tried this. But still I am facing the same issue.Please suggest.
If there is no special need you should generate your clocks in the toplevel module. This makes your life easy.
If you need the clock generation in a driver/agent you can use ‘stop_stimulus_generation’. See the UVM Reference Manual for more details.
if system verilog code. You can wrap it around dynamic process and Kill it when not necessary.
-If UVM if there are no pending objections. simulation will stop even-though forever loop is used.
