This will be implemented inside a clock, and i dont want to create 4 clocks for each case, so i thought of this way, but in simulation nothing happens.
It is helpful to post a complete example which demonstrates your issue. The following works fine:
`timescale 1ns/1ns
module case_delay();
for (int a=0; a < 100; a++) begin
$display("%t: A is %0d", $time, a);
case (a%4)
1: #1;
2: #2;
3: #3;
default: #0;
endcase
If you are generating a clock, it is recommended to use a variable delay and change the delay as required:
`timescale 1ns/1ns
module clock_generator();
bit clk;
shortint clk_delay = 10;
clk = 0;
forever #clk_delay clk = ~clk;
task update_clk_delay(input shortint new_clk_delay=10);
@(posedge clk);
clk_delay = new_clk_delay;
#500;
update_clk_delay(20);
#500;
update_clk_delay(50);
#500;
update_clk_delay(5);
#500;
$finish();
always @(posedge clk) $display("Time is %t", $time);
