I Compiled the below code, It gave the result with Cadence SImulator, Some One can please me help to understand it, Thanks
CODE:
class p;
task sum(input int a);
$display("a is %d",a);
module test;
p p1;
p1.sum(10);
Simulation Result :
irun: 15.20-s038: (c) Copyright 1995-2017 Cadence Design Systems, Inc.
Top level design units:
$unit_0x4ccdf83b
test
ncelab: *W,DSEMEL: This SystemVerilog design will be simulated as per IEEE 1800-2009 SystemVerilog simulation semantics. Use -disable_sem2009 option for turning off SV 2009 simulation semantics.
Loading snapshot worklib.test:sv … Done
ncsim: *W,DSEM2009: This SystemVerilog design is simulated as per IEEE 1800-2009 SystemVerilog simulation semantics. Use -disable_sem2009 option for turning off SV 2009 simulation semantics.
ncsim> source /incisiv/15.20/tools/inca/files/ncsimrc
ncsim> run
a is 10
ncsim: *W,RNQUIE: Simulation is complete.
ncsim> exit
Done
Thanks & Regards,
Ravi Chandra
