I am writing a checker for a frequency switcher module. Its working is very similar to that of a multiplexer where there are two inputs and a select line. The only differences are that it has a reset input and the output does not change instantaneously with change in select line/reset/input. It takes a few cycles to do that. The check as such is very simple- Verify that the output follows the input based on the select line.
My question is: How do I consider the case where an input to the switch might abruptly change frequency/ stop completely and the output would not change immediately as it takes a few cycles(assuming select line remains same throughout)? My checker is throwing errors in such scenarios so I want an approach on how to handle it.
