Hi All,
I want to use SVA to check the behavior of ID.
For example: ck0, receive ID=10, ck1, receive ID=5, ck2, receive ID=10. it is illegal case.
ck0, receive ID=10, ck1, receive ID=5, ck2, receive ID=5. it is legal case.
I want to check the transaction with different ID can not appear in clk1.
How to check it using SVA?
Thanks a lot!!
I’m not sure if I understood your problem correctly. But it seems this is not a task for SVA. Because SVA is used for checking temporal behavior of several signals.
Back to your problem:
what is ck=, ck1, etc.
what is ID is it a data member of a sequence_item?
Your question is not clear. What is the timing relationship between ck1, ck2, and ck3? If they are not synchronous, how do you establish a relationship between them? It’s also not clear which cases are legal or illegal. You should make a test stimulus that shows us the two cases.
I believe that your question is:
- I have a stream of IDs arriving in different registers each clocked with different clocks.
- The stream has a particular signature; for example:
ID==10 clocked with ck0 should arrive first,
ID==5 clocked with ck1 is next in time,
ID==5 clocked with ck2 is third.
Any other sequence pattern is in error. - The 2nd ID shouldnot be the same as the 1st ID.
The 3rd ID should be the same as the 2nd ID - There are many IDs clocked by CK1 that are illegal.
NOTE: What is poorly specificed is:
a)When is the start of IDs checked?
[Ben] I’ll assume a “go” trigger computed with support logic.
b) Is it just a sequence of 3 IDS?
c) What are the many IDs clocked by CK1 that are illegal.
bit go, ck0, ck1, ck2;
int id[0:2];
property p_id;
int v[0:1];
@(posedge ck0) (go, v[0]=id[0]) |->
@(posedge ck1) (v[0] != id[1], v[1]=id[1]) ##0
@(posedge ck2) (v[1] != id[2]);
endproperty;
ap_id: assert property(p_id);
Ben@systemverilog.us
sorry, only one clk in this problem. actually, my problem is like this.
I have a stream of same ID arriving first, and then another ID arriving next.
for example: ID=0,ID=0,ID=0,ID=0(last=1),ID=2,ID=2,ID=2,ID=2,(last=1)
I want to make sure there are no other ID between ID=0 .
for example :ID=0,ID=5,ID=5,ID=0,(last=1),ID=2,ID=2,ID=2,ID=2,(last=1)
In this example , ID=5 is illegal, because ID=0 not finish the transaction. I suppose ID should be 0 instead of 5. how to use SVA to check it?
Thank you
That clears up a few things. ck0, c1, and ck2 were ordered clock cycle sof the same clock, not different clocks. But now you have introduce a new signal last
. You could save people a lot of time by writing a small, simple verilog code declaring all the signals you need with some stimulus that we could test it with.
Maybe what you want is
property p_id;
@(posedge clk) $past(last) ==0 |-> $stable(ID);
endproperty;
