Casting into an enum
In reply to silverace99:
One can cast numbers to enums as I do here:
module cast;
	typedef bit[2:0] three_bits_t;
	typedef enum three_bits_t {
		ZERO = 0,
		ONE = 1,
		TWO = 2
	} four_e;
	four_e fe;
	initial
		for (three_bits_t ii = 0; ii <= 3; ii++) begin
			$cast(fe, ii);
			$display (fe.name());
I’ve never once looked at the UVM source code to debug a problem, so I’d assume that code is working properly.
