I have a vip in uvm world. It’s contain driver, monitor and sequencer.
I also have score board which sits in vmm world.
Iwan to send transaction fron monitor to score board which is part of vmm world.
Is there a way to send transaction from monitor to score board?
You need to use the VMM-UVM interoperability kit.
Otherwise you can define one uvm_component to mimic the UVM-VMM interoperability functionality.
Vaibhav
In reply to Vaibhav Tekale:
That I know , It’e required inter-pol kit ,
Making more specific, Will It be done by call backs method ?
or Is it need to be connect analysis port of uvm agent to vmm channel of score board by tlm2channel adapter broadcasting transaction ?
In reply to skumarsamal:
You’ll need a component that has a uvm_analysis_export on the UVM side to get the transaction from the monitor. Use a uvm_subscriber. The write() method of the subscriber will convert the transaction to VMM and put it into a vmm_channel. Your VMM scoreboard can repeatedly do blocking get() calls from the channel so when a transaction shows up the scoreboard will get it and then you can do whatever you want with it.
