Can we use repeat loop inside fork join_any?
  repeat(8)begin
  thread1();
  thread2();
join_any
In reply to Abi aadhira:
It can definitely be used. Why do you think it cannot be used ?
The simplest thing to do would be to try it out.
module test();
      repeat(2)begin
        thread1();
        thread2();
    join_any
    $display("Out of fork");
task thread1();
  #1;
  $display("Thread 1 : %t", $time);
task thread2();
  #3;
  $display("Thread 2 : %t", $time);
Output :
xcelium> run
Thread 1 : 1
Thread 2 : 4
Thread 1 : 5
Thread 2 : 8
Out of fork
xmsim: *W,RNQUIE: Simulation is complete.
xcelium> exit
I dont see any problem with the code.
Inside the repeat loop the threads are started sequentially. So thread1 will finish before thread2 starts and thread2 finishes before the thread1 of the next iteration starts.
Hope this helps.
This may be a more interesting exercsise because the threads are started in parallel
and the 8 iterations of the repeat loop will start simultaneously.
     repeat(8)  begin
           thread1();
           thread2();
        join_any
Logie Ramachandran.
In reply to KillSteal:
Thank you for your response
In reply to logie:
Thank you logie
