Can we take associative arry for assertion sequence endsequence block?
if yes then how we can store data on every posedge?
plz give me proper syntax…
Your question is not very clear, but I believe that the following answer will be OK for you.
Use a function call from a sequence match item.
That function can be used to access the associative array.
Ben Ben@systemverilog.us
