Can we set a config db in sequence body() method and get it in scoreboard?
I know that we have to set config db in build phase. But is it possible?
In reply to Subhra Bera:
You can, you just need to make sure that the set() comes before the get(). You don’t want to be doing a lot of communication this way; string based look-ups are expensive.
A better mechanism might be the uvm_event_pool, which could be a member of a shared configuration object.
Could you please give an example? I have tried in this way,
class mem_sequence extends uvm_sequence#(mem_seq_item);
`uvm_object_utils(mem_sequence)
//Constructor
function new(string name = "mem_sequence");
super.new(name);
virtual task body();
req = mem_seq_item::type_id::create("req"); //create the req (seq item)
uvm_config_db#(mem_seq_item)::set(null,"uvm_test_top.*","user_config",this.req); //set method
wait_for_grant(); //wait for grant
assert(req.randomize()); //randomize the req
send_request(req); //send req to driver
wait_for_item_done(); //wait for item done from driver
get_response(rsp); //get response from driver
And in scoreboard tried to get like this:
if(!(uvm_config_db#(mem_seq_item)::get(this,"","user_config",req1) )
`uvm_fatal(get_full_name(),{"Did not get the user Config"})
After you mentioned about uvm_event_pool I have looked into it did not understand how to incorporate that concept in my code. As per my understanding of uvm_event_pool we will create and event as soon as the sequence generates and in scoreboard we will for that event. As soon as we get that event our scoreboard run_phase will continue. Is this understanding correct? Correct me if I am wrong.
The code you are using is not good. The reason that your sequence is normally started in run_phase or sub-task-phases, but you are getting the config in run_phase of scoreboard, it will not be sure that the set() method is called before the get() method. That’s why you may not be able to get the config correctly.
As @dave_59 suggested, using event pool is the good approach for your case. Here is an example:
In your sequence, you get uvm_event from uvm_event_pool for a specific key:
//Constructor
super.new(name);
uvm_event ev = uvm_event_pool::get_global("user_config"); // key = user_config
ev.trigger(this.req);
And in your scoreboard, you get the object from uvm_event for the same key:
uvm_object data;
ev.wait_ptrigger_data(data);
$cast(req1, data);
Note:
The uvm_event becomes parameterized class which take uvm_object as default type since uvm-1.2
So, if you are using uvm-1.2 or later, please use the following code instead, to avoid any compilation error in some simulators:
uvm_event#(uvm_object) ev = uvm_event_pool::get_global("user_config");
Also, the dynamic casting $cast is necessary because uvm_event_pool uses uvm_object as default data type, snd you should use wait_ptrigger_data to avoid race condition if the wait_ptrigger_data() method is executed after trigger() method.
In reply to cuonghle:
Also, if your intent is just sending the same transaction your sequence is sending to the driver, it would be easier to set up an analysis port in the driver, and write() the transaction as the driver receives it.
